KB84200
Published: December 2, 2015
PAC Display Bring Window to Front dialog box does not work
Problem was introduced in version: R9.4a
Problem is fixed in version: R9.4e
If you have fewer than 10 windows open in PAC Display Configurator, you can click the Window menu and select the name of the window you want to bring to front. However, the Window menu only shows 9 windows. If 10 or more windows are open, a "More Windows..." selection is available. Selecting this produces the Bring Window To Front dialog box. When you select a window and click OK, nothing happens.
To access a window in the back, close or move windows that are in the front of the one you want to bring to the front.
