KB84260
Published: January 15, 2015
In groov View for Android on a Samsung device, cannot input characters or text
R2.32
On a Samsung mobile device with Android 4.4.2, when an input text box or area appears, nothing happens when you press a character on the keyboard.
Note: This issue appears to occur only with a Samsung keyboard.
There are 3 possible workarounds:
  • Long-press the first character you want to input until it appears. After that all other characters should work.
  • Use a different keyboard other than Samsung's default keyboard.
  • Turn off predictive text.
