KB84262
Published: December 10, 2014
Using SNMP, only the first 4 points of an analog module are accessible
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-EB1
SNAP-PAC-EB1-FM
SNAP-PAC-EB1-W
SNAP-PAC-EB2
SNAP-PAC-EB2-FM
SNAP-PAC-EB2-W
Problem affects versions: Firmware R9.4a and lower
Problem is fixed in version: R9.4b
Using SNMP for communication, you can access only the first four points on an analog module.
Access analog points beyond the first four by using an alternate protocol such as OptoMMP or Modbus/TCP.
NOTE that you will need both the updated firmware and an updated MIB file to complete the fix.
