KB84263
Published: December 2, 2015
PAC Display Configurator: Controller references for Table tags are not updated when importing windows
Problem affects: All versions
Problem is fixed in version: R9.4e
If you import a window and the internal controller ID of the imported window does not match the internal controller ID of the same controller in the current project, controller references may not be correctly updated. Table tags in the imported window may be undefined or reference the wrong controller.
Manually reconfigure the table tags after importing the window.
