KB84280
Published: March 7, 2016
In groov Build, dialog boxes stay open when a user is logged out by an Admin
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R1.0a - R3.0e
Problem is fixed in version: R3.1a
If you are working in groov Build and are logged out (for example, by an Admin user), dialog boxes that were open will not be removed from the page.
Close the dialog boxes or refresh the page to make them go away.
