KB84302
Published: January 15, 2015
When groov password is mistyped the "Create groov Build Account" indicator remains spinning
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3c and lower
Problem is fixed in version: R3.0a
When you create your first groov Build account, if you mistype passwords, it may look like the account is still being created. After you close the warning box, the password fields are not cleared and the "Create groov Build Account" indicator still spins.
Refresh the page, or clear the password fields and re-enter the password again.
