KB84335
Published: January 8, 2015
OptoScript compiler error when directly indexing a string table from a numeric table
PAC Control Basic
PAC Control Professional
Problem was discovered in version: R9.4a
Problem is fixed in version: R9.5c
In PAC Control, when compiling OptoScript, you receive this compiler error: Internal Compiler Error. Unknown fetch type for <numeric type> table.
This error occurs when indexing a string table directly from a numeric table, for example:
strValue = strTable[Int32Table[1]];
Assign string table index to an intermediate numeric variable instead of indexing directly from the numeric table. For example:
int32Var = Int32Table[1];
strValue = strTable[int32Var];
