KB84345
Published: December 10, 2015
PAC Control flowchart hangs when trying to access offline HART SNAP I/O
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem was discovered in version: Firmware R9.4a
If a PAC Control flowchart attempts to send or receive HART data for a HART module on an I/O unit that is offline, it may take several minutes to process the command, even if communication to the unit is disabled.
PAC Control commands affected by this issue:
- Get HART Unique Address
- Receive HART Burst Response
- Send/Receive HART Command
Before sending a HART read or write command, send an "Is I/O Unit Ready?" command.
