KB84347
Published: January 9, 2015
PAC Control Move Table to IO Unit command updates disabled points on G4EB2 I/O unit
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem was discovered in version: Firmware R9.4a
Problem is fixed in version: Firmware R9.4b
If you are using the PAC Control command "Write Numeric Table to I/O Unit" to turn off outputs on an I/O unit with a G4EB2 brain, the command turns off outputs even if the output points or communication to the G4EB2 are disabled.
Turning ON outputs is not affected by this issue.
Use individual point commands instead of a table command.
