KB84398
Published: May 4, 2015
In groov Build, tags from PAC controllers running the same strategy are indistinguishable from each other
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3a through R2.3c
R3.0a
If you add two or more controllers that are running the same strategy to your groov project, you can't tell which tag belongs to which controller when you try to add a gadget.
