KB84402
Published: March 3, 2016
The length of an OptoMMP Write Block request is not properly limited
E1 Brain Board Firmware
E2 Brain Board Firmware
Problem affects versions: E1/E2 Firmware R1.1f and lower
Problem is fixed in version: E1/E2 Firmware R1.2a
If you are writing data to the memory map on an E1 or E2 brain board and you send more data than the area contains, the board may incorrectly overwrite data in other memory map areas.
