KB84406
Published: January 19, 2015
groov: if smooth lines are chosen for a trend gadget, the gadget may not show data
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3a
In groov, if you are using a trend gadget and choose the option to draw smooth lines, the trend gadget may not display any data.
However, if there is a trend gadget with the same tag that does not have smooth lines, then any smooth-line gadget associated with the tag will work.
Either do not use smooth lines, or have two trend gadgets, one configured without smooth lines and the other with the smooth lines.
