KB84408
Published: December 2, 2015
PAC Display may freeze when closing a window with multiple graphic dynamic attributes
Problem affects versions: R9.4a - R9.4d
Problem is fixed in version: R9.4e
When a PAC Display window has an object that is configured to execute multiple actions (like send value, send discrete, etc.), if you click the object, the dynamic attribute actions have to be completed before the window can be closed, but there is no easy way to know that the actions have been completed.
If you try to close the window before the actions have been completed, PAC Display Runtime will pop up a dialog box indicating it is waiting for operations to complete. PAC Display will be stuck in this state.
To recover, shut down PAC Display Runtime and restart it.
