KB84412
Published: December 2, 2015
PAC Display: Find Tag does not find historic log items
Problem affects versions: R9.4d and lower
Problem is fixed in version: R9.4e
In PAC Display Configurator, if you choose View > Find Tags, you cannot find historic log items.
The Find Tag feature finds some items associated with Historic Data Logs, such as triggers, but it does not find other items, such as items to be logged or notifications.
The tags must be found manually.
