KB84418
Published: January 22, 2015
groov Video gadget URL does not update when a proxy is set unless you save & switch to groov View
groov View running on:
  • GROOV-AR1, GROOV-AR1-SNAP
  • GROOV-AT1, GROOV-AT1-SNAP
  • GROOV-SVR-WIN, GROOV-SVR-WIN-SNAP
R2.3b and lower
R3.0a
In groov Build, if you make changes to the URL for the video gadget and then press the Live Feed Testing play button, the URL may not have been updated.
When you make changes to the video gadget, choose File > Save All Changes and Switch to groov View. Then switch back to groov Build.
