KB84419
Published: January 23, 2015
groov Advanced Configuration settings for TRACE logging cannot be disabled once enabled
groov View running on:
  • GROOV-AR1, GROOV-AR1-SNAP
  • GROOV-AT1, GROOV-AT1-SNAP
  • GROOV-SVR-WIN, GROOV-SVR-WIN-SNAP
R2.3b and lower to current
In groov's Log Viewer (Help > View Logs), if you click Advanced Configuration and enable TRACE, you cannot then go back and disable this log level. Logging persists at the trace level previously enabled.
