KB84423
Published: January 27, 2015
After groov R2.3a or R2.3b upgrade some gadgets produce tag not configured error
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3a and higher
After installing the R2.3a or R2.3b groov App upgrade, some Text gadgets may produce the error, "This gadget does not have a properly configured tag associated with it."
This issue seems to occur on Text gadgets that are using an analog input as a tag. However, it does not happen in all such cases.
Open the page in groov Build and make any small change, then save the project, to correct the issue for that page.
