KB84424
Published: January 27, 2015
PAC Display: Changing the name of a Historic Log produces a copy
Problem affects versions: R9.4a - R9.4d
Problem is fixed in version: R9.4e
In PAC Display, when you modify a single Historic Log, it produces a new Historic Log and leaves the original in place, unchanged.
Manually delete the original historic log after the new historic log has been created.
