KB84425
Published: December 2, 2015
PAC Display Configurator may crash on Find Tag dialog box
Problem affects versions: R9.4a - R9.4d
Problem is fixed in version: R9.4e
In PAC Display Configurator, if you choose View > Find Tag and click inside the white space of the "Select Controller" area, PAC Display will crash.
If you are careful to select the control engine name itself and not click inside the white space, it will not crash.
