KB84426
Published: January 27, 2015
E1/E2: DNS Server cannot be set when brainboard has a static IP address
Problem affects versions: Firmware R1.1e and lower
Problem is fixed in version: Firmware R1.2a
If a static IP address is assigned to an E1 or E2, you will not be able to configure a DNS server address. The address will be stuck as 0.0.0.0
