KB84428
Published: January 27, 2015
E1/E2: Host and Domain Names cannot be edited
Problem affects versions: Firmware R1.1e and lower
Problem is fixed in version: Firmware R1.2a
If you try to set the Host Name on an E1 or E2 brainboard to a non-default value (default is OPTO-44-55-66, where 44-55-66 are the last 3 bytes of the brainboard's MAC address), the Host Name is not set and instead reverts to the default value.
You also cannot change the default Domain name. In addition, if a static IP address is set for the E1 or E2, the Domain name disappears.
