KB84432
Published: February 2, 2015
groov App: Can't turn on/off digital output point using Modbus communication in groov
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem was introduced in version: Groov App R2.3a
Problem is fixed in version: groov App R2.3c
If a button is created that is supposed to turn on or off a digital output using Modbus to communicate to the brain or controller I/O, pressing the button causes a yellow triangle to appear. If you click on the triangle, an error indicates that the value could not be written.
