KB84457
Published: May 4, 2015
groov usernames and passwords cannot include special characters (%, &, etc.)
groov View running on:
- GROOV-AR1, GROOV-AR1-SNAP
- GROOV-AT1, GROOV-AT1-SNAP
- GROOV-SVR-WIN, GROOV-SVR-WIN-SNAP
R2.3a through R2.3c
R3.0a
If you use special characters (that is, any character other than a number or a letter) when you set up your first groov Build username and password, you'll receive an error that says the passwords don't match.
If you use special characters when you set up other users' usernames and passwords, they will appear to work; but when users try to log into groov View, they will receive the error message "Username/Password combination not found."
Use only numeric and alphabetic characters in a groov username or password.
