KB84474
Published: December 10, 2015
Some time zone changes not working correctly in SNAP PAC controllers
SNAP-PAC-S1-FM
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem affects: Firmware R9.4b and lower
In SNAP PAC controllers, when you use the PAC Control command Set Time Zone Configuration to set the time zone to change at any time past 2:55 a.m., the controller is not updated correctly.
IMPORTANT: This fix will cause stored time zone information to be
cleared. After updating firmware on the controller, make sure you run the Set Time Zone Configuration
command in PAC Control to restore the time zones.
