KB84523
Published: February 18, 2015
Unused points on E1/E2 brains can be configured
Problem affects: All versions
The E1 and E2 brain boards can use only point 0 of each module on the rack, but points 1-3 are also configurable. Configuring these points has no effect on the E1/E2.
Ignore points 1-3.
