KB84538
Published: December 2, 2015
Error downloading PAC Control strategy with PID loop
PAC Control Basic
PAC Control Professional
Problem affects versions: R9.4b
Problem is fixed in version: R9.4c
When you update a PAC Control strategy from an earlier version of PAC Control to version R9.4b, PID output configuration is lost. This issue occurs with any strategy PID that has its output configured to go to an analog output point.
Downloading the strategy may fail or hang part way through when the PAC resets itself, or the download may show an error, for example:
"Empty stack error. Control engine attempted to perform an operation that expected data on the control engine stack.
Code: -60"
Reconfigure the PID outputs.
