KB84542
Published: November 25, 2015
Missing options for analog outputs in PAC-DEV-OPTOMMP-DOTNET SDK
.NET OptoMMP Software Development Kit for SNAP PAC
Problem affects versions: R3.0.0.0 through R3.0.2.0
Problem is fixed in version: R3.0.3.0
If you are using Opto 22's .NET OptoMMP Software Development Kit for SNAP PAC to write to analog outputs using AnalogState4096(), you see only engineering units and counts. Additional options should be available.
