KB84556
Published: December 2, 2015
PAC Control: Can't configure On-Latch Set? or Off-Latch Set? when I/O unit is G4EB2
PAC Control Basic
PAC Control Professional
Problem affects versions: R9.4b and lower
Problem is fixed in version: R9.4c
In PAC Control, if you try to use the conditions On-Latch Set? and Off-Latch set?, points for a G4EB2 I/O unit do not appear in the list of available points.
