KB84591
Published: March 24, 2015
E1/E2 brain board may be unresponsive after changing IP settings
Problem affects versions: Firmware R1.1d and R1.1e
Problem is fixed in version: Firmware R1.2a
When using the Change IP Settings tool in PAC Manager to change the IP settings on an E1 or E2 brain board, you may receive an error message: "Communication error with 192.168.0.1 - 0xFFFFFFFE". Afterwards your device may become unresponsive. Once the device is responding again, you will see that the IP settings have been changed.
- Cycle power on the E1 or E2.
- If that doesn't work, in PAC Manager choose Tools > Find Opto 22 MMP Devices. Check to see if the device reset and is sending a BootP request.
- If the device is still unresponsive, contact Opto22 Product Support.
