KB84606
Published: December 2, 2015
An OptoControl strategy with scaled points will not convert properly to PAC Control
PAC Control Professional
Versions affected: R9.4b or newer
Problem is fixed in version: R9.4e
An OptoControl strategy with scaled points will not convert properly to PAC Control. The PAC Control conversion report for each scaled point states "Cannot convert analog point: [point name]."
The points will not appear in the strategy tree. If you attempt to access the points on the Configure IO Points dialog PAC Control will crash.
This only affects OptoControl strategies going straight to PAC Control Pro R9.4b or newer.
Open the OptoControl strategy in PAC Control R9.4a or earlier. The resulting strategy can then be opened in PAC Control R9.4b or newer.
