KB84608
Published: December 10, 2015
HART preambles set to very high value
SNAP-PAC-S1-FM
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects versions: Firmware R9.4a and R9.4b
This issue may occur if you are using a HART SNAP I/O module in a PAC Control strategy. When a HART command is sent, the number of preambles may be set incorrectly, to a very high value.
The HART protocol operation is not affected by this incorrect value.
