KB84693
Published: June 17, 2022
In Build mode of groov View, changing gadget z-order only works with one gadget at a time
Firmware for the following groov EPIC processors:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
- GROOV-AT1, GROOV-AT1-SNAP
For groov EPIC processors: All versions prior to 3.4.0
For all other part numbers: All versions prior to 4.4a
For groov EPIC processors: 3.4.0
For all other part numbers: 4.4a
In Build mode of groov View, even when you select multiple gadgets, you can send only one gadget to the back or the front at a time.
Change each gadget's z-order separately.
