KB84696
Published: April 17, 2015
Message Queue doesn't propagate from active to backup redundant controller
SNAP-PAC-S1-FM
Problem affects: Firmware, all versions
If you are using SNAP PAC S-series controllers as redundant controllers (with the SNAP-PAC-ROK redundancy option kit), errors placed in the Message Queue of the active controller are not propagated to the backup controller. If there is a switch to the backup, any queued errors are lost.
Use an error handling chart with sync blocks to pull errors from the Message Queue and write them to a persistent string table. When a sync block is executed, changes to the persistent string table will be propagated to the backup.
