KB84703
Published: October 8, 2015
groov project takes a long time to save if Trends have missing tags
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN-BASE
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects: groov App R2.2 and higher
Problem is fixed in version: R3.2a
When you're saving a project in groov Build, if a Trend gadget has pens whose tags have been deleted, saving can take a long time. The time required to save the project varies based on the number of trends with deleted tags and the groov platform you're using.
Delete the trends with the missing tags, or assign valid tags to the pens in the trend.
