KB84704
Published: December 10, 2015
Controller may reset if email attachment is sent from microSD card
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-S1-FM
Problem affects versions: Firmware R9.4a to current
Sending emails with attachments from the microSD card can cause the controller to reset under some conditions. The reset occurs only if the attached files are loaded from the microSD card using the SDHC file system.
Use firmware R9.3c or older (does not support SDHC).
--or--
Attach files only from controller RAM file system.
