KB84711
Published: December 10, 2015
Opening a communication handle may cause a controller reset (or bus error) if value is malformed
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-S1-FM
SOFTPAC
Problem affects: Firmware, all versions
In PAC Control, using an incorrect communication handle may result in a -16 Bus error in the controller's Message Queue, and on a hardware controller the controller may reset.
For example, a value of F:\HTE\RD150415.T0000 is missing the comm handle type, such as file or tcp. When the handle is opened, it will cause an error or reset.
Make sure all required elements are included in your comm handle value. See the PAC Control User's Guide for help.
