KB84712
Published: October 23, 2015
groov Build: Some incorrect colors appear with dark backgrounds
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: groov App R2.3
Problem is fixed in version: groov App R3.0a
In groov Build, when you add a Range Indicator gadget to a page with a dark background, the initial colors are not all correct. You may see black label text instead of white. The incorrect colors appear initially but are corrected when you come back to the page.
Try one of these three workarounds to see the correct color:
- Go to another page and back.
- Reset the page's color.
- Go to groov View and back.
