KB84713
Published: April 29, 2015
Missing incompatible project warnings in groov
GROOV-AR1-SNAP
GROOV-AR1
GROOV-SVR-WIN-SNAP
GROOV-SVR-WIN
Problem affects: All versions
Problem is fixed in version: R3.1a
If you downgrade groov to a previous version, you should see a warning message about incompatibility. This message does not appear.
Use the most recent version of groov.
