KB84719
Published: December 10, 2015
On a SNAP PAC controller, the host port may become unresponsive
SNAP-PAC-S1-FM
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects: Firmware R9.4a and higher
If the controller is not able to access an I/O unit and tries to re-enable communication to that I/O unit, and a host requests any tags from the controller related to that I/O unit or its I/O points, then the controller's host port may become unresponsive.
Make sure that your I/O units are accessible. If you know an I/O unit won't be accessible, disable communication to that I/O unit and don't attempt to enable communication to it.
