KB84735
Published: April 29, 2015
SoftPAC waits forever to receive a string
Problem affects versions: Firmware R9.4a and R9.4b
Problem is fixed in version: Firmware R9.4c
If a command to receive a string is executed from SoftPAC, but the data in the receive buffer does not include an EOM character (or a CR, if no EOM is specified), SoftPAC will wait forever. This issue can also occur if the receive buffer contains no data at all.
Attempting to stop SoftPAC or its strategy will result in a lockup, requiring the PC to be rebooted.
Before attempting to receive a string, use the Get Number of Characters Waiting command followed by a Receive N Chars command, to ensure that the requested
data is available.
