KB84757
Published: December 10, 2015
PAC Control: Unpack String incorrectly stores 8-, 16-, and 24-bit values into Int32
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-S1-FM
SOFTPAC
Problem affects versions: Firmware R9.4a and higher
If you use the PAC Control command Unpack String to unpack a value of less than 32 bits into an Int32 in Little Endian order, the unpacked bytes are incorrectly stored to the most significant bytes of the Int32 rather than to the least significant bytes.
