KB84805
Published: June 5, 2015
groov: Changed Opto 22 controller IP address does not immediately appear in the gadget palette
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects version: R3.0a
R3.0b
In groov Build under Configure > Devices and Tags, you can change the IP address for an Opto 22 controller. However, the changed IP address is not immediately shown in the Gadget Palette Tags list.
After changing the IP address, refresh the page.
--OR--
Choose File > Save All Changes and Switch to groov View, and then switch back into groov Build.
