KB84833
Published: November 16, 2015
OptoScript: "if-then" causes -13 overflow error when value is too large
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SNAP-PAC-S1-FM
SOFTPAC
Problem was discovered in version: R9.4e; Lower versions may also be affected
If an OptoScript block has an "if (My_Integer64) then" statement and if the value of My_Integer64 is greater than
7FFFFFF hex (2,147,483,647 decimal), then a -13 Overflow error is placed in the controller's message queue.
Use a 64-bit comparison instead.
Examples:
if (IsVariableTrue(My_Integer64)) then
or
if (My_Integer64 <> 0i64) then
