KB84834
Published: June 26, 2015
Revision: 4.0
PAC Control does not scale SNAP-AIMA-iH and SNAP-AOA-23-iH (HART modules) correctly
PAC Control Basic
PAC Control Professional
Problem affects versions: R9.4a and higher
When you scale a HART module (SNAP-AIMA-iH or SNAP-AOA-23-iH) in PAC Control, the zero-scale value is set to 4.0 and the full-scale value to 20. These should be 3.2 and 24.0, respectively, to use the full resolution of the module.
Set the Actual Lower Scaling value to 3.2 and the Actual Upper Scaling value to 24.0.
