KB84845
Published: March 23, 2016
EtherNet/IP Configurator does not scale SNAP-AIMA-iH and SNAP-AOA-23-iH (HART modules) correctly
EtherNet/IP Configuration Software
Versions affected: R3.0k, R3.0l, R3.0m
R3.0n
When you scale a HART module (SNAP-AIMA-iH or SNAP-AOA-23-iH) in EtherNet/IP Configurator, the zero-scale value is set to 4.0 and the full-scale value to 20. These should be 3.2 and 24.0, respectively, to use the full resolution of the module.
Set the Actual Lower Scaling value to 3.2 and the Actual Upper Scaling value to 24.0.
