KB84879
Published: March 28, 2016
groov Server stops functioning; NoClassDefFoundError exceptions appear in message log
groov Server running on:
- GROOV-SVR-WIN-BASE
- GROOV-SVR-WIN
- GROOV-SVR-WIN-SNAP
R3.1a and lower
R3.1b
You are unable to access groov Build or groov View using groov Server for Windows. When you open the Message Logs, you see errors similar to this:
java.lang.NoClassDefFoundError: com/opto22/groov/shared/PlatformInformation
While
groov is running, some files may be unpacked into the Windows temporary directory. Some PC utilities delete files in that directory as part of a periodic clean-up process. If
groov files have been deleted,
groov cannot function correctly.
Determine whether any software is running that will delete files in the Windows temporary directory, and prevent it from doing so.
You can use the Microsoft’s Process Monitor utility to help diagnose what software running on your PC is deleting the files: https://technet.microsoft.com/en-us/library/bb896645.aspx
