KB84895
Published: July 28, 2015
PAC Display Configurator: Historical Log configuration crash
Problem affects versions: R9.0a and higher
If you configure logging to file using a trigger (either SuperTrend or Historical Logging), when you click the "?" button to select the trigger tag, PAC Display Configurator will crash.
