KB84906
Published: December 10, 2015
SNAP PAC controller resets when doing secure SMTP over PPP
SNAP-PAC-S1-FM
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem affects: Firmware - All versions
If you are communicating over PPP, when you try to use the PAC Control command Send Email, the controller resets while trying to establish a secure connection to the SMTP server.
If possible, use a method other than PPP.
