KB84909
Published: August 13, 2015
Cannot resize Level, Slider, or Divider groov gadgets in Chrome
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0b and lower
In groov Build, when you try to change the size of a Level, Slider, or Divider gadget, the gadget is not properly rendered.
This is an issue only if you are using the Chrome web browser.
Deselect and then reselect the gadget. Or use Firefox, Internet Explorer, or Safari instead of Chrome.
