KB84951
Published: December 10, 2015
SNAP PAC controllers: Set Time Zone Configuration is not saved to battery-backed RAM
SNAP-PAC-S1-FM
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects: Firmware R9.4b and higher
When you set the controller's time zone configuration, the configuration is not correctly saved. If power to the controller goes off, the time zone configuration is lost and the controller's time zone reverts to UTC.
Add a Set Time Zone Configuration command to Block 0 of the Powerup chart.
